3205 Questions
0 Members and 1 Guest are viewing this topic. Read 1661 times.
WEEZ
3205 Questions
« on: 7 Apr 2007, 01:54 am »
Hi Bill,
I don't want to make this too long or complicated, but I've read the info on your site and have a few questions. I'm posting this here because hopefully others may be curious too. :)
1) Does the Platinum Mkll (12AU7) version change the input sensitivity (gain) from the Signature (12AX7) version? Still 500mv?
2) If one opts for the integrated version (of either one), is there room for a DACT, Goldpoint, or similar volume control in lieu of the ALPS?
3) If one opts for the integrated; is there room for a record output in addition to the (4) inputs?
4) Is there a way to get a 6 ohm output tap as an option?
5) Are custom paint colors still available?..as well as the wood front plates?
I realize there would be up-charges for this stuff..(just wondering how 'custom' one could go)  8)
WEEZ
(you have a PM on another totally different matter)
WEEZ
Re: 3205 Questions
« Reply #1 on: 9 Apr 2007, 11:04 pm »
Bill Baker
    • Musica Bella Audio
Re: 3205 Questions
« Reply #2 on: 9 Apr 2007, 11:39 pm »
Sorry Weez, I don't get email notifications and this one slipped by. I'll addres sthe PM after done here.
 No problem at all. Thank you.
 It still remains around the 500mV .
 Yes, I have built them with all of the above.
 Absolutely. Done quite a few with tape outputs. Mostly for CD recorders.
 No, there is no 6 ohm tap on the transformer. Most run 6 ohm loads from the 8 ohm tap.
 Yes, both custom paint and powder coating.
As far as you imagination will allow.
WEEZ
Re: 3205 Questions
« Reply #3 on: 9 Apr 2007, 11:51 pm »
Thanks much for the info!!
 :thumb:
WEEZ
