Other Stuff
Archived Manufacturer Circles
NuForce
Use both inputs?
Use both inputs?
0 Members and 1 Guest are viewing this topic. Read 1295 times.
isernia63
Newbie
Use both inputs?
7 Apr 2007, 01:03 am »
I wonder if the 9.02s can receive both on both inputs (XLR and Normal) and use the switch to select between them or just turn one source or the other one...
Any experience with this?
Mik
rustydoglim
Industry Contributor
ยป
Re: Use both inputs?
7 Apr 2007, 09:05 am »
This question comes up now and then. The answer is no. The manual also say so
Yes, technical you can if you are 100% sure only one of the input is on. The switch only changes the ground wiring and doesn't switch the signal inputs.
Other Stuff
NuForce
Use both inputs?
