New here, help me choose a 2 channel amp!
0 Members and 1 Guest are viewing this topic. Read 6970 times.
keanej6
« on: 5 Apr 2007, 10:35 pm »
Hey all.
I bought a pair of JBL control 1 xtreme bookshelf speakers a while back.  http://www.jbl.com/home/products/product_detail.aspx?prod=CONTROL1XTREME&Language=ENG&Country=US&Region=USA&cat=BFS&ser=COS
I was going to power them with my brother's old KLH receiver but it sounds awful.  So now i need a new amp.  I was looking at http://www.audiosource.net/2005/amponea.html.  I know it's not high end, i just want a cheap amp that will power my speakers ok. I do my critical listening through my headphone setup. Any recommendations?
WEEZ
Re: New here, help me choose a 2 channel amp!
« Reply #1 on: 5 Apr 2007, 10:42 pm »
Looks like it'll do the job. How much does it cost, may I ask?
Welcome to AC :thumb:, btw
WEEZ
Charles Calkins
« Reply #3 on: 5 Apr 2007, 10:58 pm »
Can't go wrong for $100.00 Plus Amazon has a great return policy.
If you decide not to get this one I suggest you look at the Behringer A-500 amp at Parts Express.
                                                     Cheers
                                                    Charlie
jkelly
« Reply #4 on: 5 Apr 2007, 11:04 pm »
Can I ask if you ever heard them sound good and what amp was driving them?
Jeff
WEEZ
« Reply #5 on: 5 Apr 2007, 11:05 pm »
Parts Express has a Sherwood 2ch Receiver for $80 bucks too.....
Hi dad, er...Charles :oops:
WEEZ :wave:
mjosef
« Reply #6 on: 5 Apr 2007, 11:18 pm »
The Audiosource amp is good at the price point, I have the 80w X 2 model. It should drive that JBL speaker just fine.
BubbleChamber
« Reply #7 on: 8 Apr 2007, 06:44 pm »
If you want something cheap and decent, I would suggest getting the T-Amp, a decent power supply(>3 Amp) and a mini-RCA adapter. Total cost of around $50. I have one hooked up in my office connecting to a pair of Canton mini bookshelves. Sounds pretty nice.
Obad_Imports
    • Obad Imports
doug s.
  • makin' music
« Reply #9 on: 7 May 2007, 12:07 am »
i second the trends, based upon a buddy of mine who likes his, & said it outperformed the sonic-t.  he sent me this interesting "shootout":
http://www.stereomojo.com/SHOOTOUT2007INTEGRATEDS.htm
doug s.
Try the Trends TA-10.1
http://www.musical.ca/catalog/item/4377302/4344389.htm
enrique
« Reply #10 on: 7 May 2007, 12:34 am »
can someone explain how a 15w amp like the trends is any good as compared to a regular amp like rotel,audio refinement etc.Or even the amp i'm actually interested in the red dragon which is i believe 125w.
doug s.
  • makin' music
« Reply #11 on: 7 May 2007, 12:49 am »
because it sounds better?   :lol:  seriously, if your speakers are efficient enough &/or you room is not huge, 15wpc may be all the power you need.  then, it's up to how you like the amp as it performs driving your speakers.
i found that review i quoted pretty interesting, since the speakers used are the ls6's, designed by gr-research's dannie richie; & also included in the shoot-out are the well-thought-of nuforce amps - both these companies get a lot of press here on a/c.
doug s.
Gordy
« Reply #12 on: 7 May 2007, 01:13 am »
Obad, have you read this sticky?  http://www.audiocircle.com/index.php?topic=36051.0
PhishPhan
« Reply #13 on: 7 May 2007, 01:33 am »
It's about quality over quantity.
doug s.
  • makin' music
« Reply #14 on: 7 May 2007, 02:29 am »
i got interested in this trends amp - sucked into the internet again!   :duh:  anyway, there's an interesting review of the trends on 6moons, & links to a guy who mods them, as well as a shop where you can buy the amps awreddy modded, or mod kits, if you wanna save a few dollars & diy.  (they also sell other t-amps & mod kits for them.)  the full-zoot modded to the max trends amp sells for $279...
http://www.6moons.com/audioreviews/trends/ta10.html
http://www.michael.mardis.com/sonic/start.html
http://www.audiomagus.com/index.php?page=shop.product_details&category_id=2&flypage=shop.flypage_modern&product_id=20&option=com_virtuemart&Itemid=27
http://www.audiomagus.com/index.php?option=com_virtuemart&page=shop.browse&category_id=14&Itemid=59
myself, i think i will still stick w/tubes - i *did* try a sharp digital amp, & it was excellent.  but tubes are better, imo...  :wink:
doug s.
enrique
« Reply #15 on: 7 May 2007, 02:29 pm »
doug s.
well my room is 21 x19 my speakers are System Audios they are 4-8ohm w/90db using a rotel rsx1056.Is a little amp like that or even a red dragon going to do anything for me.Sorry for the ignorance.
doug s.
  • makin' music
« Reply #16 on: 7 May 2007, 03:49 pm »
imo, the 10-15wpc of the trends amp will be marginal in a 19x21 room w/90db-efficient speakers.  it will be ok, but you may have issues if you wanna crank it up.
i am not familiar w/the red dragon amp, tho i have read a couple positive things about it...  its power should be more than sufficient, tho.  personally, i would go for tubes, depending on your budget.  as low as 20-25w of tube power would be ok, but i would think 40w would be better...
hth,
doug s.
[/quote]well my room is 21 x19 my speakers are System Audios they are 4-8ohm w/90db using a rotel rsx1056.Is a little amp like that or even a red dragon going to do anything for me.Sorry for the ignorance.
[/quote]
robert1325
« Reply #17 on: 7 May 2007, 04:04 pm »
Yeah,
The trends really rocks with efficient speakers... I tried some 90db minimonitors (8ohm) and it did sound nice at low volumes...
enrique
« Reply #18 on: 7 May 2007, 04:30 pm »
The red dragon is 105w they are monoblocks so i would obviously need 2.I saw a pr that's available but now i'm torn between the red dragon and an audio refinement multi3 which is 125 x3.I'm looking for a cool running and low profile that basically coukld be hidden.But to be honest my rotel has been doing fine on it's own.I dont want to buy something that if i will not need it and there wont be any difference.any duggestions?
doug s.
  • makin' music
« Reply #19 on: 7 May 2007, 04:56 pm »
buy used, so you can try different gear, then sell what comes in second, w/o taking a financial beating...
doug s.
