diy parts...
0 Members and 1 Guest are viewing this topic. Read 2479 times.
JoshK
diy parts...
« on: 4 Apr 2007, 11:43 pm »
Thought I'd post this here as well since there are some diy'er here...
I have a bunch of parts I ended up not using in projects. I always over order:
--4x 14uf/180vac (~300VDC) Aerovox oil caps (motor run type) says "no pcbs" $5/ea
--2x 4 channel motorized Alps 50K audio taper pots $15/ea
--4x 15,000uf/80v Samwha Caps 'lytic $5/ea (used but not soldered) (3.75 by 1 5/8 not including tabs)
I'll try to up some pictures later.
« Last Edit: 30 Mar 2008, 06:49 pm by JoshK »
JoshK
Re: diy parts...
« Reply #1 on: 5 Apr 2007, 02:29 am »
mjosef
Re: diy parts...
« Reply #2 on: 5 Apr 2007, 08:47 pm »
Hey Josh, can you check the dimensions of both the 15,000uf/80v Cornell-Dubilier & Samwha Caps?
I could use 4 of these but I need to know the size.
Thanks.
mjosef
Re: diy parts...
« Reply #3 on: 5 Apr 2007, 10:29 pm »
Great I will take 4 of the C-D, since they are smaller.
gbeard
  • Contributing writer--Positive Feedback
Re: diy parts...
« Reply #4 on: 1 May 2007, 02:10 am »
Howdy Josh,
How many steps are the Slagle AVCs?
Gary
gbeard
Re: diy parts...
« Reply #5 on: 1 May 2007, 10:11 am »
Thanks. Just bought a pair.... :(  Damn!
JoshK
Re: diy parts...
« Reply #6 on: 30 Mar 2008, 06:50 pm »
Ad has been updated for what is left.....wife says I to start getting rid of stuff so this is a spring cleaning sales.
