LED circuit on Cornet
0 Members and 1 Guest are viewing this topic. Read 1542 times.
sonata149
« on: 4 Apr 2007, 05:24 pm »
I'm using a different power transformer which gives me about 340V smoothed HT.  When I switch on the preamp the LED immediately goes from red to green. I'm not sure the result of solid state rectification, or because I need to adjust voltage divider values connected to B+ (R107-R108).  If this is the case can someone please advise which resistor to scale down (or up?) and what value to try?
Thanks for a great sounding design.
hagtech
    • http://www.hagtech.com
Re: LED circuit on Cornet
« Reply #1 on: 4 Apr 2007, 06:19 pm »
If you are using SS rectifiers, then there will be virtually no delay before LED turns green, indicating high voltage is present.
jh
Free Radical
« Reply #2 on: 5 Apr 2007, 04:49 am »
My Cornet II changes to green in less than 3 seconds.  All components are as per build sheets.  I've tried different 5Y3GT's and a 5Y3G, all with the same results.
It was easy to build and sounds wonderful by the way, I'm just a little concerned that I might be abusing the cathodes.
Regards
samplesj
« Reply #3 on: 5 Apr 2007, 12:41 pm »
Aren't most 5Y3 fast start?  Its just happens that the Sovtek 5Y3 is a slow starter.  Depending on what you've tried they may all be the fast type.
Maybe try a 5AR4/GZ34?  They are all slow start.  Its a drop in replacement (no other changes needed).  It'll give you a bit higher B+ voltage too.
