Finished!!!!!!
0 Members and 1 Guest are viewing this topic. Read 2876 times.
Popms
Finished!!!!!!
« on: 27 Jul 2003, 03:42 am »
Justed finished 1801b, Sc300 sub combo tonight. Only been playing about an hour, this combo is amazing, I love it.
EProvenzano
Re: Finished!!!!!!
« Reply #1 on: 27 Jul 2003, 04:08 am »
Quote from: Popms
Congrats!
Hope to see some pics when you have a chance.
Have fun!
EP
David Ellis
    • http://www.ellisaudio.com
Finished!!!!!!
« Reply #2 on: 28 Jul 2003, 04:12 pm »
Where do you have the subwoofer located.  I stopped using mine because it skewed the soundstage in the general direction of the subwoofer.
I heard another setup with a subwoofer located perfectly in the center that sounded quite nice.
Also, could you please share the general construction details & dimensions for your cabinet.
Dave
Finished!!!!!!
« Reply #3 on: 28 Jul 2003, 05:07 pm »
For a 2 channel setup, stereo subs are the only way to go, IMO.  VERY nice when you have it setup well.
Al Garay
Finished!!!!!!
« Reply #4 on: 28 Jul 2003, 08:07 pm »
Please give specifics about your SCC300 sub. I'm still waiting for my amp to arrive.
Al
EProvenzano
Finished!!!!!!
« Reply #5 on: 28 Jul 2003, 09:15 pm »
Quote from: Tyson
I couldn't agree with you more Tyson.
As it seems that one sub can skew the image badly, conversely two subs can miraculously make your sound stage expand many feet wider. My SCC300's are corner loaded outside my monitors and the sound stage is enveloping. No single contribution or tweak to my system ever had such a dramatic effect to the sound stage  :D
BR,
EP
Popms
Finished!!!!!!
« Reply #6 on: 29 Jul 2003, 04:59 pm »
For now I located the sub in the corner on the outside of the speakers, I plan on trying other locations later. As for now it seems to blend in good its just so much better than what I had before, I've just been enjoying how much better it is.  As far as constuction it is 18*18*21 internal w/2 vertical braces with about 50% removed which I figured roughly at 3.7 cu. ft. it has 1.5 in. top, bottom and sides and 2.25 in. front and back. I also used a Art Of Sound amp. And this thing is HEAVY, in a pinch could also use it as a jack stand
Al Garay
Finished!!!!!!
« Reply #7 on: 30 Jul 2003, 02:57 am »
What is the crossover point?
What did you use for internal wiring?
Did you use MDF only? Did you use any internal dampening material?
Al
