R-DES questions
0 Members and 1 Guest are viewing this topic. Read 1686 times.
mfsoa
R-DES questions
« on: 30 Mar 2007, 02:00 pm »
Can someone please tell me, what is the highest frquency is that R-DES can adjust? (Highest selectable center frequency)
Also, is there really no significant time delay when using R-DES? Like if you wanted to use it in a bi-amp situation on the woofers only - I'm looking for assurance that there won't be any phase issues introduced with R-DES before the woofer amp.
-Mike
Mike Dzurko
Re: R-DES questions
« Reply #1 on: 30 Mar 2007, 02:27 pm »
-Mike
Mike:
The time delay isn't an issue. I will check on the center frequency tonight when I get home. Or if someone else has the software in front of them . . . .
Mike Dzurko
Re: R-DES questions
« Reply #2 on: 31 Mar 2007, 12:52 pm »
Mike:
120Hz    :D
mfsoa
Re: R-DES questions
« Reply #3 on: 31 Mar 2007, 08:49 pm »
Thanks, Mike
If I understand correctly, the R-DES can be used without any low-pass filtering (run full range) if you set the crossover frequency to the highest setting.
True?
Thanks again,
Mike
Mike Dzurko
Re: R-DES questions
« Reply #4 on: 31 Mar 2007, 09:07 pm »
Thanks, Mike
True?
Thanks again,
Mike
Mike:
Actually the highest you can set the crossover is 120Hz and you choose between 2nd order or 4th order. There is no crossover "defeat".
