DirecTV HD-DVR - Can programs be copied to a DVD
0 Members and 1 Guest are viewing this topic. Read 1595 times.
Captain Humble
« on: 29 Mar 2007, 07:46 pm »
I recently switched from cable to DirecTV.
I also purchased one HD-DVR and one regular DVR.
Is there a way to dump recorded programs out of the DVR and onto a DVD?
If not is there a way to save recorded programs to any other media so the DVR doesn't run out of disc space?
Jeff
jqp
Re: DirecTV HD-DVR - Can programs be copied to a DVD
« Reply #1 on: 1 Apr 2007, 01:49 am »
What is the model number of your DVRs? Are they from DirecTV?
I have heard that output from these DVRs is usually limited to SVHS quality, that is you can plug an svhs cable in and record to a DVD Recorder or SVHS VCR.
Also you may not be able to copy some content, such as HBO movies or Series, or you may have to do the DVD-R VR mode (which allows only one copy).
Captain Humble
« Reply #2 on: 1 Apr 2007, 01:55 pm »
The high def is called DIRECTV Plus HD DVR.  The other one is the same without the HD feature.
Yes.
I found the books yesterday and there are several options for "out to tv" from the DVR that can also be used to connect a VCR or DVD Recorder.
The next step will be to pick up a few cables and experiment.
Thanks for responding jqp.
jqp
« Reply #3 on: 1 Apr 2007, 08:26 pm »
Here is "101 Undocumented HR20 (Plus HD DVR) Tips & Tricks"
There is a pdf at the bottom of the page...
http://www.dbstalk.com/showthread.php?s=40872a1325f18aae34638766ad517783&t=72648
