SLA Batteries in the UK - sources?
0 Members and 1 Guest are viewing this topic. Read 1040 times.
Reverie
    • My Myspace
« on: 29 Mar 2007, 07:03 pm »
Hey all,
I'm looking for a pair of 12V ~5ah SLA batteries to power my 41hz amp4 mod (you may have seen me planning the circuit in other threads...).
However, I can't find a good source in the UK. Ideally, I'm after something that has a short height, and longer width and length (to fit into chasis easier). Something like this from
Battery Mart would be ideal, and if I can't find as good in the UK, I'll probably pay to have them shipped over.
Any help appreciated!  :)
Peter.
Jampot
Re: SLA Batteries in the UK - sources?
« Reply #1 on: 29 Mar 2007, 07:57 pm »
Here
http://www.mdsbattery.co.uk/shop/productprofile.asp?Model=HC1217W&ProductGroupID=1610&Brand=CSB%20Battery%20HC%20range&DepartmentName=CSB%20Battery%20range&DepartmentID=181
£12
If you look at the Battery Mart listing it has 'equivalents' - the first one drew a blank but google found this when I put in RBC21.
Apparently it is used in UPSs. I think PC World has them but they didn't list dimensions.
Any time now the Lidl will have 'leisure baterry packs'. Nice plastic carry case, on / off /charge switch, a selection of plug ends, and taps for 4.5 - 6 - 9 & 12 volts. About 15quid when I bought one 2 years ago for a Sonic Impact Tamp....
Hope you get fixed up OK.
Jim
Reverie
    • My Myspace
« Reply #2 on: 29 Mar 2007, 08:28 pm »
That looks great.
One thing though - I'm not sure whether that one, or this:
http://www.mdsbattery.co.uk/shop/productprofile.asp?Model=HC1221W&ProductGroupID=1024&Brand=CSB%20Battery%20HC%20range&DepartmentName=CSB%20Battery%20range&DepartmentID=181
Slightly different one, is a better match. However that one above says 5.1Ah, and the other one doesn't state; whereas the battery mart one was 5.5ah...differences of opinon?
Thanks again.  :D
