Moving From a PC to a Mac I Will Need Some New Software
0 Members and 1 Guest are viewing this topic. Read 1656 times.
datman
I am looking at switching from my PC (Windows XP Pro) to an iMac.  My question is whether or not there is software that is functionally equivalent to Exact Audio Copy, FLAC encoder and foobar2000.  For the foobar software, I need something that will allow me to bypass the computer sound and connect directly to my usb headphone amp.  EAC and FLAC are what I am using to record my cd's onto a hard drive in FLAC format.
Any help will  be greatly appreciated.
konut
Re: Moving From a PC to a Mac I Will Need Some New Software
« Reply #1 on: 29 Mar 2007, 05:04 am »
If you run Parallels on the iMac, you can run OSX and XP at the same time. If you wait there is a rumour that Leopard will support FLAC in iTunes, due out shortly. Then there is also Bootcamp which allows you to either boot up to OSX or XP.
Wayne1
« Reply #2 on: 29 Mar 2007, 01:59 pm »
For playback of .flac files on a Mac, you can use COG http://cogosx.sourceforge.net/
Songbird  http://www.songbirdnest.com/
or VLC  http://www.videolan.org/vlc/index.html
For ripping files, MAX seems to be the program of choice:
http://sbooth.org/Max/
avta
« Reply #3 on: 29 Mar 2007, 02:15 pm »
I'll ditto Wayne's comments. I made the switch to a Mac ( Mac Mini G4 ) about 2 years ago and wondered why I waited so long. There are some free or inexpensive utilities that I've found helpful so when you get to that point let us know.
Guy
Watson
« Reply #4 on: 29 Mar 2007, 02:23 pm »
Unlike Windows, where prior to Vista there was a need to bypass kMixer with either kernel streaming or ASIO, there is no need to use special software to bypass the computer sound in Mac OS X.  Macs are bit-perfect out of the box.  No special software needed.  Everything, including iTunes, is bit-perfect (provided you turn off the equalizer and "Sound Check", the normalizer, obviously).
The functional equivalent to EAC on OS X is called "Max".  It uses Unix cdparanoia behind the scenes.  The only real player with a significant following other than iTunes on OS X is "Cog" which can be found on the same website as "Max."  Songbird will also play FLAC and has a bit of a following.  Most Mac users use iTunes, simply because it works well and there is no reason not to, but if you want a traditional player with no library functions, Cog is good.
iTunes does not support FLAC directly.  One thing to think about or consider is using dbPowerAmp before you switch to convert your FLAC files to ALAC, which is Apple's Lossless format.  Then all your music would be accessible in iTunes.
If you really have specific needs that can't be met with Songbird, most of the Linux media players like Amarok can be made to work on OS X.
