Zu Druids different versions
0 Members and 1 Guest are viewing this topic. Read 882 times.
Johnb
« on: 27 Mar 2007, 06:09 pm »
I am planing on buing a pair used of Zu Driuds. I think they are made late 2005. My question is do anyone know what model that could be, the Druids selling know are Mk4. My second qqustions is if there are any major differences between the different modells or is just marketing?
Thanks in advance
John
miklorsmith
Re: Zu Druids different versions
« Reply #1 on: 27 Mar 2007, 06:16 pm »
Late 2005 should be MK4, but the seller should be able to tell you.
Johnb
« Reply #2 on: 27 Mar 2007, 08:48 pm »
Thank you, does it say on the speaker which model it is?
John
miklorsmith
« Reply #3 on: 27 Mar 2007, 09:11 pm »
It doesn't appear that the MK4 is stamped on the aluminum rear plate.  There might be a serial number that Zu could check for you.  I think the machined supertweeter on the front was new with the MK4 but don't quote me on it.  Zu should be able to give you something definitive to check.
Orf
« Reply #4 on: 27 Mar 2007, 10:09 pm »
The receipt contains the model number.
As to the Druid's history, go the source - I've found the folks at Zu to be very generous whenever I've called with questions.
