Source Gain Adjustment - Analog modded SB3
0 Members and 1 Guest are viewing this topic. Read 1924 times.
whdean
« on: 26 Mar 2007, 03:22 am »
I have an SB3 with Wayne for full mods as I write this -
I understand that the modded analog output will be lower to some degree as a result of removing a portion of the SB3 output circuitry. I will be feeding the SB3 analog into the 6-channel bypass inputs of my Parasound AVC-2500u pre/pro. While these inputs do not involve the pre/pro's DAC or its digital processing, the source gain on each of the unit's inputs, including the pass-thru inputs, is adjustable by plus/minus 16 db.
I will certainly tinker with that when I receive the SB3 back, but I was curuous if any of the more technicla folks would care to venture a guess as to how much lower the modded SB3 would be - Would it likely be w/in the range of 16 db?
TomS
Re: Source Gain Adjustment - Analog modded SB3
« Reply #1 on: 26 Mar 2007, 11:50 am »
Should be well within the range.  I am using the Burson Buffer which increases it 6db.  Tom
gitarretyp
« Reply #2 on: 26 Mar 2007, 03:32 pm »
With the sb3's opamp removed, the maximum output voltage is halved. So, you lose 6db with the mods, which is easily compensated for by your pre/pro's gain settings.
whdean
« Reply #3 on: 26 Mar 2007, 11:04 pm »
Thanks to both of you -
That's great news for me.
