SKA skpre with squeezebox, as buffer/ active output stage ?
0 Members and 1 Guest are viewing this topic. Read 942 times.
robert1325
Hi,
I know Greg Ball has been banned from this forum but I would like to say that his SKA skpre might be a good option as buffer between the SB and power amp for people with mismatches....  with and without volume control....  It's a lot cheaper than the Burson buffer and might give people more flexibility in terms of using it as pre or as buffer.
I'm planning on trying it myself ( I''ll just make an integrated of my trends ta-10)    I'll write something about it once i've tried it.  It got some good reviews over at the diyaudio forum :D
Still very happy with my SB ,  but comparing it to my dads beefy Wadia 23 output , there's is a big difference in dynamics and bass .  I do think the SB is a bit more natural.   Hope the Skpre will help !
http://www.diyhifi.org/amplifierguru/guru_008.htm
Robert
gitarretyp
I've been considering doing the same thing, so i'll be very curious to hear your results. Are you planning to build it with or without the volume control? I discussed using the skpre with greg a while ago, and the conclusion we came to was to use a fixed gain of 6db with an increased input impedance since the sb3's DAC is designed for a minimum 10kohm load and i'd rather err on the side of caution.
robert1325
Don't know when I'm going to do it,  but surely will !  might be in a couple of weeks  :thumb:  The plan is to use it with a volume control. ( don't trust the SB / white noise)   My SB is modified by boldercables, it has a cap coupled, passive output.... Yours is to?   Thing is,  I'm going to do some mods on my t-amp and want to know what the improvements are before doing anything else (might consider another better amp)
Robert
robert1325
Short update, I ordered the boards and will probably have them next week sometime.... I'll report back on the results  :P
« Last Edit: 1 Apr 2007, 01:24 pm by robert1325 »
