Loudspeaker sensitivity.
0 Members and 1 Guest are viewing this topic. Read 1921 times.
DaveX
« on: 25 Mar 2007, 03:48 pm »
Lets say the D200's 200 watts @ 8ohms requires an 8ohm loudspeaker of 89db sensitivity 1W @ 1m to achieve an 105db peak. What would the db's sensitivity of a 4ohm loudspeaker need to be to achieve the same 105db peak if the D200's put out 325 watts @ 4 ohms into a 4ohm loudspeaker.  Thanks.
CIAudio
    • http://www.ciaudio.com
Re: Loudspeaker sensitivity.
« Reply #1 on: 25 Mar 2007, 05:17 pm »
Do a search on Google for SPL calculator...you'll find many of them.
