0 Members and 1 Guest are viewing this topic. Read 1906 times.
From the clues provided, I'm inclined to think it may be mechanical vibration rather than an electrical problem (static, etc).I would ask him if he can consistently induce or alter the buzzing sound by stomping his foot or tapping on other surfaces in the room. There may be something in or near the amp that is creating a sympathetic vibration, in much the same way as you can induce vibration in a guitar string by holding a vibrating tuning fork near it. What a mystery.Lensman
Does the TV have a lamp chord 2 prong plug or earthed 3 prong plug? Did he use any cheaters anywhere? Can he try moving the TV out of the system to see if it is something with the TV being introduced? If the amp is unplugged and still makes noise, is the TV unplugged too? I am just wondering if the TV's tx is causing some EMF reaction in the iron in the tube amp. Kind of like how unshielded speakers react with a TV.
Does he live in a cold & dry climate? Those climates tend to have a lot of static electricity build up in the winter which could be exacerbating the issue if it were EMF related.
It's hard diagnosing a problem over the phone without being able to experience the noise first hand.
