Switch recommendation
0 Members and 1 Guest are viewing this topic. Read 1024 times.
jrebman
« on: 21 Mar 2007, 10:18 pm »
I hope this doesn't annoy too many folks here, but I need some advice on a high-quality, small 4pdt switch -- preferrably with silver contacts.  This is for a phono preamp so quality is important, as is small size, but not current or voltage capacity -- i.e. -- will not be used for switching AC power.
I've just never bought any small toggle switches so don't even know what the quality brands are.
TIA,
Jim
Dan Banquer
Re: Switch recommendation
« Reply #1 on: 21 Mar 2007, 10:34 pm »
C&K makes excellent switches. You can find them listed at Digikey & Mouser.
                d.b.
jrebman
« Reply #2 on: 23 Mar 2007, 07:58 pm »
Dan,
Thanks, I ordered one as well as a NKK, so I guess we'll just see what happens though in a non-signal, low voltage, low-current application, I can't imagine there are going to be any significant differences.
-- Jim
Dan Banquer
« Reply #3 on: 23 Mar 2007, 08:06 pm »
Dan,
-- Jim
You're probably right.
                 d.b.
