Hemp Bipoles - 16 ohm efficiency rating
0 Members and 1 Guest are viewing this topic. Read 1624 times.
rajacat
  • Washington State
« on: 19 Mar 2007, 05:38 pm »
Louis,
When the Hemp Bipoles V1 are wired for 16 ohms instead of the rated 4 ohms how does this effect the efficiency rating and to what degree?
Do the 4.5 Hemps have the same efficiency as the Fostex's?
Raj
« Last Edit: 19 Mar 2007, 06:07 pm by rajacat »
Louis O
Re: Hemp Bipoles - 16 ohm efficiency rating
« Reply #1 on: 19 Mar 2007, 11:42 pm »
Hi Rajacat,
The SPL would be 93 and in 4 ohm 96. In 16 ohms the speakers is more efficient though and an easier load on the amp, preferably tube. 4 ohm is great for most SS.
Thanks again,
Louis
