tube amp comparison
0 Members and 1 Guest are viewing this topic. Read 1205 times.
marvda1
  • freelance reviewer: The Sound Advocate
tube amp comparison
« on: 18 Mar 2007, 06:19 pm »
anyone compared the response audio Bella Extreme 3205 mk2 to the Bizzy Bee Tad-60 tube amp?
both are 60 watts and pretty close in price.  which one would be better at driving 8 ohm 87 db. speakers?
Klucznik
Re: tube amp comparison
« Reply #1 on: 18 Mar 2007, 08:02 pm »
Marvda1,
I won't be able to offer any comparisons, but if all goes as planned, I'll be listening to the Response 3205 through my 86db 4-7 Ohm Vandersteen 2ceSigs on Tuesday.  If you think it would be any help, I can let you know how the 3205 managed them when I get back from Endicott (home of Response Audio).
Ken K
JoshK
« Reply #2 on: 18 Mar 2007, 08:06 pm »
Do you have an impedance curve of your speakers?  How about phase curve?  Sensitivity isn't all there is to know.  How loud to do you like to play?  How big of a room?
marvda1
« Reply #3 on: 18 Mar 2007, 08:59 pm »
my room is 12x15x8 i listen maybe no more than 75-80 db most of the time.
i don't have any plots on the speakers will have to check to see if there are any out there.
Bucky
« Reply #4 on: 20 Mar 2007, 01:58 am »
I have the TAD-60 with 86 dB 8 ohm speakers in a room larger than yours and there are no issues.
JoshK
« Reply #5 on: 20 Mar 2007, 02:04 am »
again, the 86 sensitivity doesn't tell the whole story...impedance and reactance play just as much if not more a role in whether x watts is enough.
arthurs
« Reply #6 on: 20 Mar 2007, 03:12 am »
Marvin, you should get a pair of Lamm ML2.1's so we can all hear what they sound like!    :D
marvda1
« Reply #7 on: 20 Mar 2007, 03:45 am »
OUCH!!, can't bankroll the 2.1's but the ML1.2's will be in next weekend :lol:
marvin
