0 Members and 1 Guest are viewing this topic. Read 4114 times.
Try throwing a Felix power conditioner on your Plasma or LCD. Inexpensive and easy to build. Makes a nice improvement.Enjoy,Bob
It's scary that all the TV manufacturers don't have their "normal" setting calibrated to ISF when you buy them. Not sure why they wouldn't, but that's the case.
You can counteract any hue shift of the picture by adding a complimentary-colored cable jacket. So if your image is skewing towards green, get a magenta-jacketed cable. Likewise if the image is too dark you'll want a whiter cable jacket. If the image is blurry you can take a razor blade and shave off the round rubber jacket so if forms more of a square shape to sharpen up the image. But be careful with woven cable jackets as they can often cause moiré\herringbone patterns on certain images.
