Break in Bent Audio MU step ups with FryKleaner?
0 Members and 1 Guest are viewing this topic. Read 1916 times.
robbiesurp
« on: 17 Mar 2007, 10:28 pm »
Is there any problem hooking my Bent Audio MU step up transformers for break in with the FryKleaner? I think they are set at 1:10 gain now. Which volume setting should I use on the FryKleaner? Is there a certain signal path that I need to use when hooking them up?
hagtech
Re: Break in Bent Audio MU step ups with FryKleaner?
« Reply #1 on: 18 Mar 2007, 06:43 pm »
These trannys can handle huge signals.  I used to burn them in using the HI setting.  For current mode burn, I would short the outputs.  That puts the ESR of the secondary as the load.  Forces the core into action with a lot of flux.  You might prefer a compromise, use a 1k load instead.
jh
robbiesurp
« Reply #2 on: 18 Mar 2007, 07:07 pm »
Thanks Jim!
Does this mean that i can run them into one side of the frykleaner and then out to the other set of inputs on the frykleaner? Sorry for my lack of technical knowledge.
hagtech
« Reply #3 on: 20 Mar 2007, 01:59 am »
Just drive the primary side.
jh
robbiesurp
« Reply #4 on: 30 Jun 2007, 09:30 pm »
jh
Does this mean connect the J2 & J3 outputs of the Frykleaner to the inputs of the MU only? Nothing is plugged into J4 & J5 on the Frykleaner and the outputs of the MU are not connected to anything either? Just want to clarify this. thanks!
hagtech
« Reply #5 on: 1 Jul 2007, 06:47 pm »
Yup.
