What are my options for improving stock PS for SB3?
0 Members and 1 Guest are viewing this topic. Read 1172 times.
Rob S.
« on: 16 Mar 2007, 07:21 pm »
HI all,
   HOpe this is the right location for this request.  I have a stock SB3 and I remember reading threads a while back on improvements to the Power supply.  What are some good choices for the PS improvements?
Purchase one  or build one ( if it's relatively simple )?
And for those that have switched, can you really 'hear a difference'?
Rob S.
JDUBS
Re: What are my options for improving stock PS for SB3?
« Reply #1 on: 16 Mar 2007, 11:17 pm »
HI all,
Rob S.
Rob, have you searched the forums?  There's a bunch of info about sb power supplies.
That said...there's a lot of ways you can head...from the mild (stock ELPAC) to the wild (Bolder Cables Ultimate Mk. II).
They all yield a difference from the stock switcher...the degree of difference depends on the resolution of the rest of your system.
-Jim
Scott F.
« Reply #2 on: 16 Mar 2007, 11:28 pm »
Rob,
Here is a link from the Square Circle on various Squeezebox links on AC.
http://www.audiocircle.com/index.php?topic=22603.0
If you go to the last post on page one, you'll find mine where there is another link to the PS discussions.
Hope that helps.
Rob S.
« Reply #3 on: 17 Mar 2007, 02:55 am »
Thanks guys, just getting lazy and wanting some quick answers without lots of research.   I'll do some reading now.
With a $300 device, can't justify doing Bolder "macDaddy" PS.  But could maybe rationalize doing up to $150 or so.  View it as some decent interconnects.
Rob S.
