Big B, announces availabiity of NEW VSS 15", 120 oz magnet, Bass Driver
0 Members and 1 Guest are viewing this topic. Read 8217 times.
SleeperSupra
John,
It's nice to be here.  :D  I never knew about the VMPS forum, found it by accident.   :)
My passive radiator and the surround look perfect.
Is the plug painted black to match the cabinet?
Any pictures of the 15" driver? Is it a poly cone or woven carbon?
Any specs on it like power handling, efficiency, or possibly a good guess of what the in room -3dB point will be after it's installed?
I should be calling you soon to do the upgrade.   :drool:
Thanks,  :thumb:
Bob
Early B.
I always wondered why the Tall Boy cabinet is no longer offered. I actually prefer the looks of the Tall Boy over the "horizontal" design of the 215 that I own or the New Larger cabinets. Takes up less floor space, too. I even tipped my 215 on its side, but it didn't look very good. Did WAF kill the Tall Boy?
John Casler
John,
Thanks,  :thumb:
Bob
I beleive the plug/plate is black, but B can confirm that, as I have not seen one.
Here is the 15" ULTRA-MegaWoofer mounted in the VSS.
In the VSS cabinet, it is said to have the following performance:
In the VSS cabinet it is zero dB down at 20Hz and will reproduce subsonics (-10dB/14Hz nearfield). Weight is 22 lbs for the driver.
B, will have to fill in other numbers.
