Can I use a 9V battery trick on a Larger subwoofer...
0 Members and 1 Guest are viewing this topic. Read 1595 times.
ctviggen
to check polarity?  I think one of the woofers is wired out of phase with the other.  Will the 9V battery trick (connecting the 9V battery to the input terminals and seeing which way the cones move) work on the Larger, or is there not enough "oomph" with the 9V battery?
mjosef
Re: Can I use a 9V battery trick on a Larger subwoofer...
« Reply #1 on: 15 Mar 2007, 11:52 pm »
My Original sub with mega woofer responds well enough with just a AA 1.5v... 9v sounds like too much.
John Casler
« Reply #2 on: 16 Mar 2007, 02:31 pm »
Hi All,
I moved Brian's response about the "NEW" availability of the 15", 120 oz magnet Megawoofer to it's own thread.
