0 Members and 1 Guest are viewing this topic. Read 3825 times.
Very nice. I like the "color", too! This would be the style I would get (though I'd get some internal upgrades, like better caps, etc.). Any idea how reflective these are? Do you think this style or a wood style would disappear better in a dimly lit home theater room? In other words, if these are placed near a 110 inch screen, would black or wood be better in terms of the amount of light the speaker would reflect?
hey jim,what is the best type of paint to use to get a satin black finish.thanks,drmike
drmike-Quote from: drmike on 15 Jun 2007, 01:19 amhey jim,what is the best type of paint to use to get a satin black finish.thanks,drmikeI don't know if this is the best or not. But what we do is shoot sealer coats until the surface can be sanded totally smooth to 400 grit. We then spray the cabinet with black lacquer-based stain. We follow that up with about 5 coats of gloss lacquer and one final coat of satin lacquer. Use of the gloss keeps the finish clear, while the final satin coat provides the desired gloss level.We can use this same process and add a little pearl powder to the initial gloss lacquer coats to produce a black "pearl" finish.I hope this helps.- Jim
