My RWA SB3: Is it charging? Does it need a new battery?
0 Members and 1 Guest are viewing this topic. Read 2305 times.
RuefulR
Just got a used modded SB3.  The charger's LED will only glow green.  SB will power up via the AC connection, but there's no battery power.
Does this mean it needs a battery replacement?  The other possibility I'm looking at is a faulty switch.  "SW2" wiggles around in its socket.  However, that switch is working to the extent that it can connect or disconnect the AC power supply.
And I was so looking forward to listening to this thing!   :cry:
Vinnie R.
    • http://www.vinnierossi.com
Re: My RWA SB3: Is it charging? Does it need a new battery?
« Reply #1 on: 14 Mar 2007, 03:26 am »
Hi RuefulR,
Welcome aboard!
If the charger LED on the 2000mA charger (which is the one that I included with the SB3) never goes RED, this *most likely* means that the battery voltage is too low for it to be charged.  The charger will not go into charge mode if the battery voltage is below approx 10V.  What you have is most likely a dead battery, and it needs to be replaced.  Please contact me at [email protected] and I will discuss your options to either have me replace it for you, or recommend you a replacement battery (available online) if you wish to try and replace it yourself.
That is the one thing that tricky about buying used RWA products... you don't know how the previous owner took care of the battery. :scratch:   Even if you deep cycle the battery (play longer than the recommended play time) one once with the SB3 (and even if you are still able to charge it), you will significantly reduce its lifespan  :!:.
SLA batteries do not like to be deep cycled, and I mention this in the modded SB3 User's Guide and other info about careful charging habbits.  If you did not receive this, I can email you a copy.
If you have any other questions, please let me know.
Best regards,
Vinnie
