Industry Circles
Audio by Van Alstine
jimava
SACD's
SACD's
0 Members and 1 Guest are viewing this topic. Read 2410 times.
martyo
SACD's
12 Mar 2007, 11:46 pm »
I could use some help, knowledge. I was on another forum and they were hyped about a petition to the record labels to recommit to producing SACD's because they have the highest resolution. I'm embarrassed to admit
that i don't know or understand all the CD formats. I read a little on Wikapedia and it was talking about 1 bit processors. I thought that that was part of the problem with the "digital sound". Could someone enlighten me?
Marty
Audiovista
Industry Contributor
Re: SACD's
13 Mar 2007, 02:30 am »
Marty,
I'm not an expert in this field, but I believe the correct term should be a 1-bit D/A conversion. Which is a "creative marketing" (I heard it first time from Technics in early 90-ies) for a serial D/A converters. Basically there are two types of DACs - parallel inputs (a 16-bit DAC will have 16 input pins) and serial DAC, where there is one input pin and signal is fed in a serial manner. Obvious advantage of a serial DAC is that there is a lower number of pins and, therefore, lower cost for the manufacturer.
This is way oversimplified, but may get you on the right track.
Check the websites of Analog Devices, Texas Instruments and Linear Technology (among quite a few others) - there is a lot of useful info (look for application notes) should you desire to dig deeper.
www.ti.com
www.analog.com
www.linear.com
Last Edit: 13 Mar 2007, 11:24 am by Audiovista
dB Cooper
Re: SACD's
Reply #2 on:
13 Mar 2007, 02:33 am »
Here is something that I actually saw the link to on this site:
http://www.mother-of-tone.com/conversion.htm
martyo
Re: SACD's
Reply #3 on:
13 Mar 2007, 09:40 am »
Oooohhhhh! Thanks alot for the info.
Marty
avahifi
Re: SACD's
Reply #4 on:
13 Mar 2007, 03:44 pm »
Or, why AVA uses a 16-bit parallel processing DAC.
Frank
martyo
Re: SACD's
Reply #5 on:
13 Mar 2007, 11:18 pm »
Thanks Frank
alotaklipsch
Re: SACD's
Reply #6 on:
14 Mar 2007, 01:44 am »
http://www.stevehoffman.tv/forums/
check out the threads on the steve hoffman forum
Rob Babcock
Volunteer
Re: SACD's
Reply #7 on:
20 Mar 2007, 07:31 am »
RIP, SACD- It seemed like a good idea at the time.
Toka
Re: SACD's
Reply #8 on:
20 Mar 2007, 02:45 pm »
Yea...good idea, but a day late and a dollar short (or several years late and several bits short, whichever you prefer). Using the cheapo 1-bit method was just plain silly, IMO...you either make the best or don't bother.
Industry Circles
jimava
SACD's
