Need some help
0 Members and 1 Guest are viewing this topic. Read 1756 times.
Hallet
Need some help
« on: 11 Mar 2007, 07:04 pm »
Hello guys i have a very dumb question. i have all my gear now i just got my cables & i need some help
setting my sys up I'm very new to this & am not sure how to connects the inter connect in the right order
this is what i have .  Bryston 4b-sst amp, bryston sp-2, classe delta cd player . for now i will just be using
it in two Chanel with a pair of b&W 804'S i have a dd 12 sub but i think i will need help setting that up
as you can tell by my questions I'm very green to this. thanks for your help .
woodsyi
Re: Need some help
« Reply #1 on: 11 Mar 2007, 08:45 pm »
Well,
You certainly are starting with a bang.  Nice gear.  It may be best for someone to come by and assist you as you set everything up.  Where do you live?
Hallet
Re: Need some help
« Reply #2 on: 11 Mar 2007, 08:51 pm »
 :green: i know not starting off to good . i live in Lakehavasu arizona.
  thanks any way .
mjosef
Re: Need some help
« Reply #3 on: 11 Mar 2007, 10:40 pm »
Here is a guide from Monster Cable website.
http://www.monstercable.com/hookup_learning/csg/
Usually your amp or preamp manual would come with a hook up diagram.
Your sources connect to your preamp, your preamp connects to your amp and your speakers connect to your amp. Pretty basic. No right or wrong way.
Powering up and down the system has a right and wrong way. You power up from the source side first, or from preamp to amp with a few seconds between to allow the preamp delay circuit (if any) to switch out. Other wise you may get a big thump from your speakers. And on powering off the system, start by turning off the amp first, wait a few seconds, then preamp.
Hallet
Re: Need some help
« Reply #4 on: 11 Mar 2007, 11:38 pm »
Thanks mjosef how about the cd player.
thanks again for your help.
Hallet
Re: Need some help
« Reply #5 on: 12 Mar 2007, 02:11 am »
Thanks guys i found the problem i need single ended cales on the sp-2  :duh:
