0 Members and 1 Guest are viewing this topic. Read 6188 times.
Lonewolfny - from your post it seems that you are inferring that in some instances single driver speakers are a more appropriate match for this amp - which seems consistent with what 90% of owners seem to have from what I have read.
Is that possibly because large full range speakers don't work well with the SET style output (ie: is it suited more to a smaller speaker), or is it more likely a function of price (ie: do people with $15k speakers naturally look at amps in the $5k+ range and therefore discount the 30?). Please keep in mind that the Proac's are a full range 3 way with claimed frequency response of 20hz (which I would believe).
The other difficulty I have is regarding return (and possibly even delivery) as I live in Australia. That might be a question for Vinnie - speaking of which also is anyone aware of whether 240v conversion is straightforward with the 30?
Thanks Chris. Was there any other commentary with that picture?
Can it realistically do the job though?Additionally, the Proac's are 91 db & 4 ohms.
Such a little amp among the giants..... (it is small -but it worked).
Can't speak for the Sig 30' but I was the first of three or four purchasers of the Sig 70. My room is 19 x 12.5 x 9 and my speakers are 4 ohm, 92db efficiency. If I turned the amps full up I am not sure which they would damage first -- my eardrums or the windows. BTW,my speakers are 4 way.
Alternatively, I could presumably consider a DAC with volume control, and run from there straight into the 70's?
Vinnie,I guess a pre-amp could be a possibility. I was originally trying to avoid going that route, but it may be worthwhile if I consider the 70's. Anyone able to suggest a good inexpensive pre-amp suitable with the 70's? Only criteria: remote volume control, and minimal impact on the sound passed through (oh yeah - and no tubes. Like the sound but not interested in the hassle). Alternatively, I could presumably consider a DAC with volume control, and run from there straight into the 70's?
