Talk about a gushing front projector review....
0 Members and 1 Guest are viewing this topic. Read 2959 times.
ctviggen
« on: 9 Mar 2007, 05:03 pm »
http://www.projectorreviews.com/jvc/DLA-RS1/index.asp
I think he likes it!  A bit expensive for my tastes, though.
Rob Babcock
Re: Talk about a gushing front projector review....
« Reply #1 on: 10 Mar 2007, 03:46 am »
The JVC is probably the most anticipated PJ in recent memory.  If it's half as good as he claims it a real bargain even at that price.
Papajin
« Reply #2 on: 10 Mar 2007, 07:42 am »
Projector Central just posted theirs too:
http://www.projectorcentral.com/jvc_dla-rs1.htm
While it may not be the perfect projector, it seems like it gives you great bang for the buck if the reviews are any indication.
Big Red Machine
« Reply #3 on: 10 Mar 2007, 01:34 pm »
I've got one on order.  Let's keep our fingers crossed! :rock:
Woodsea
« Reply #4 on: 10 Mar 2007, 01:39 pm »
That looks sweet.  Outta my price range and to soon for replacement for me.  But, makes happy to see that I will be getting a huge leap in ressies next time.
jermmd
« Reply #5 on: 10 Mar 2007, 02:22 pm »
I'm at the bottom of the AVS pre-order list for this projector and it has already shipped to people at the top of the list. I should be hearing soon. I'm still not certain whether or not I'll buy it because my present projector is fine. I suppose I could sell my Panny 900. The reviews really put the JVC projector into a new league.
ctviggen
« Reply #6 on: 10 Mar 2007, 02:43 pm »
The reviews do place the JVC into a new league.  The only negatives I've seen posted (which may not be negatives, depending on your point of view) are whiter corners (for a few), lack of a color management system, and no access to the hidden menus used for color/greyscale (the latter I'm not so sure about; this was talked about prior to the release).
Supposedly, the pre-buy was a good deal.  From all accounts, the JVC would be much better than the Panny. You'd have to upgrade to Blu-ray, HD-DVD, then!
srlaudio
    • SRL Acoustics
« Reply #7 on: 10 Mar 2007, 03:58 pm »
We have been a fan of the Lcos technology for a long time.......We have this and many other great things available.....
JohninCR
« Reply #8 on: 10 Mar 2007, 08:46 pm »
I'm sure it's a great PJ, but I'm going to wait it out.  2 or 3 years tops and that kind of quality will be sub $1k, with long-life cheap bulbs and widely adjustable brightness.    Until then I can live with the PJ I have.  No hi-def signals here anyway.
griller
« Reply #9 on: 28 Mar 2007, 08:07 pm »
I'm in the same boat on this one. Will wait another couple of years and then pounce!
