Dh Labs product need advise on connectors
0 Members and 1 Guest are viewing this topic. Read 1957 times.
chgolatin2
« on: 9 Mar 2007, 03:03 pm »
Since I am on a budget I purchase a set of suprisingly good "used" Dh Labs Q10 bi wired cables however they came with Z plugs for the amp end and spades for the speaker end since I got a good deal on them I took the bite and made the purchase.  I have a set of VSA Vr2's speakers, the spade are super large and even though I could connect them to the back of my speaker their a PITA  :scratch: the z plugs banana work well attaching them to the amp end side and quite easy, nice and sturdy/tight the speaker side is a tad bit loose and I have to apply alot of pressure to make good contact.
Ok here is my dilema, the spade are super large also they look like cheap quality gold plated crap the banana ends are ok. Yeah yeah I know what most of are you probably are thinking "you purchase used cables so dont complain" well, I am not I am just looking for a better connector for the spade end side and possibly replace the banana side end with a better quality connector.  I like the banana and rca type of plugs, easier to remove etc.  Considering going the DIY route for this or just making a good purchase on the connectors and having my audio shop finish the job for me.  What connectors are the best for my cable needs (besides spades which I dont like) newbie~  like the KISS principle.  I've heard of Cardas Rhodium/Silver connectors are fairly good but I personally dont know.  Thanks to all in advance for the help~!  :thumb:  I need something that matches the cables well and my needs.
gooberdude
Re: Dh Labs product need advise on connectors
« Reply #1 on: 9 Mar 2007, 03:51 pm »
what about bare wires on both ends of the speakers?
DH labs uses good copper, try and put nothing between you and the music.
