PMC Product Line Brochure
0 Members and 1 Guest are viewing this topic. Read 1489 times.
Bob Reynolds
« on: 9 Mar 2007, 12:19 am »
I was unable to locate a brochure/catalog that provides an overview of the entire pro and consumer line of PMC speakers on the PMC web site. Does anyone know if such a thing exists?
Also, which models (either 2-way or 3-way) can be actively bi- or tri-amped with external amplifiers?
Bob
  • The Demo is Everything!
    • http://www.bryston.com
Re: PMC Product Line Brochure
« Reply #1 on: 9 Mar 2007, 12:26 am »
HI Bob,
There is an Active/Passive PRO PMC Brochure and a Consumer PMC brochure but not both in one.
The MB2 and the BB5 can be purchased as Active version systems.
james
Bob Reynolds
« Reply #2 on: 9 Mar 2007, 04:06 am »
james
Thanks James. Can you tell me how I can get a copy of both brochures?
I found the pro brochure, so I only need the consumer brochure if there are any consumer monitors without pro counterparts.
« Last Edit: 9 Mar 2007, 05:24 am by Bob Reynolds »
