Design for new listening room
0 Members and 1 Guest are viewing this topic. Read 939 times.
robert44
« on: 8 Mar 2007, 08:37 pm »
I would like to get opinions on room dimensions for sound...I am designing a new listening room and am wondering if the "golden room" dimensions still apply....This would be approx. 16' wide by 23' long by 10' high...(or any multiple of this)....thanks, robert.
HChi
Re: Design for new listening room
« Reply #1 on: 8 Mar 2007, 09:08 pm »
If I were to build one from scratch, I will follow the Golden ratio as well.  Depending how low you would like to go (frequency-wise),  with 23' you could get close to 20Hz.  If you would like to get into high teens, you could consider making it slightly bigger. :)
