0 Members and 1 Guest are viewing this topic. Read 6573 times.
Fancy/expensive tonearms wires/leads have yielded zero improvement here over time....I've had Audio-Technica PC-OCC, Hitachi LC-OFC.....just leads that attached snugly (using a bit of Caig to make sure the metal doesn't oxidize ecery so often) seems to work fine. It's 2" to fret over and seems to not matter much at all. Meanwhile there are hundreds of feet of wire in the coils of your cartridge that is likely not anything fancy (some makers advertise PC-OCC, 6 nines copper, however). As most don't, they are probably using any old razor thin copper piano wire within. Then there is the 4' or so from your tonearm to your preamp to be more concerned about. Basic headshell leads go for about $10....but you can buy the whole headshell and stainless steel mounting from the ever reliable Tim at www.turntablebasics.com for $10 + $4 = $14.00. You can take the leads and put it on the ceramic headshell and you'll be styling
I can see the sense in your arguments. I'll find some cheapies. My headshell does have gold connections though so I guess I will seek the same in my leads. Thanks for talking me back to earth.You know, that might be a useful service in this hobby. When a guy is out on a ledge about to jump into a $6000 upgrade, he could just call you and get the help he needs to return to terra firma safely. This service would be especially useful as a counter to clocks and cables and tweaks. Think about it.
Gary,I'm using a Technics SP-10 MK II table with their obsidian base and a Technics EPA 100 MK II tonearm. This stuff is primo. That's why I was wondering about the quality of the leads. The SAEC Ultimate headshell is supposed to be one of the best and rarest according to the guy who sold me the table. It cerainly is well machined and rigid. I'm currently using a Denon DL 103 but I also have a ZYX R-1000 Airy which has cryoed coils. My questions at this point are all about staying good enough. I'm done with overkill.
The massive 'fly in that ointment' is that I am often irrational, too...you caught me on a good stable day As I get older I get a tad wiser....it's part of the payback for not being able to play a good game of tennis or stay up late drinking anymore without discomfort I obsess over enough in this hobby...I draw the line at 2" length of wire aaQuote from: macrojack on 8 Mar 2007, 05:23 pmI can see the sense in your arguments. I'll find some cheapies. My headshell does have gold connections though so I guess I will seek the same in my leads. Thanks for talking me back to earth.You know, that might be a useful service in this hobby. When a guy is out on a ledge about to jump into a $6000 upgrade, he could just call you and get the help he needs to return to terra firma safely. This service would be especially useful as a counter to clocks and cables and tweaks. Think about it.
I routinely and regularly Caig De-Oxit and Pro-Gold each joint in the chain to minimize arcing and other problems involved with any joint in the chain.
