0 Members and 1 Guest are viewing this topic. Read 3606 times.
Of course, results will vary with rooms, equipment, etc.
FWIW I'm in favor of toeing in rather than out, so the axes cross in front of the listening area - tends to give a wider sweet spot and the nulls off to the sides are aimed at the wall between and behind the speakers, diminishing a major reflection and further improving imaging and the side walls, doing the same.
One of the things I found intriguing is the mention made by some others that an 18-inch baffle width is the best for imaging. I have always found that the less width there is on the front baffle the better for imaging. CheersLuigi
