TAS full page ad...
0 Members and 1 Guest are viewing this topic. Read 2017 times.
pearsall001
  • AAD 2001 monitor
TAS full page ad...
« on: 6 Mar 2007, 04:05 am »
I'm glad to see Frank hitting the mags to spread the word about his exceptional products. But this ad in particular is some what unappealing. The wording is very intising along with the inside picture, but the color of the amp is so far off it's not even funny. If I didn't know what Frank's gear looked like I would not be intised to seek him out for a "fatigue green" amp. Please do a color check on your next ad to show the real AVA gear. Your gear is top shelf & deserves better color print.
honesthoff
Re: TAS full page ad...
« Reply #1 on: 6 Mar 2007, 07:16 pm »
The AVA ads in Sensible Sound always looked pretty good to me.
pearsall001
  • AAD 2001 monitor
« Reply #2 on: 6 Mar 2007, 07:38 pm »
I've seen Franks ads in other mags also & the pictures were first rate. They really did his products justice. But, for some reason the April/May TAS ad is just awful looking. If a picture is worth a thousand words then the amp color in this ad is a very short sentence. Maybe I'm nit pickin but as consumers our first attraction to a product is usually visual. Eye candy this one isn't.
avahifi
    • http://www.avahifi.com
« Reply #3 on: 6 Mar 2007, 10:21 pm »
I have given my web and adv. guy a "heads up" regarding the color balance of the faceplate of the Ultra 550 in the 550 amp in the TAS adv. that you are unhappy with.  We will fix it.  Thanx.  The amp sounds better than it looks, and looks better than the photo.
Frank Van Alstine
EDS_
« Reply #4 on: 9 Mar 2007, 01:26 am »
Frank Van Alstine
Hi Frank,
Not to pile on......I'm looking at your AVA Transcendence Eight pre-amp ad in the March '07 TAS.
Either the flash is yielding very yellow light and/or the "studio lighting" is too yellow or the printing plate and seperation process is yielding too much yellow. Alternatively, if the printer is using a digital pre-press system maybe your files do not work well with their RIP software. Their color profiles are set to particular levels and your file copy may need yellow attentuation. The net is an identical file may yield masterpiece level copy in one magazine and much less so in another.
As you likely know, four color process printing uses cyan (blue), magenta (red), yellow and black dots in precise patters to fool us into seeing something like photorealistic images.  Looking through a 10 power loop-the four color build of your pre-amp is simply too yellow. "Yellow" blacks are printing sins. Red blacks are a little better-but still look terrible sometimes. Blue blacks look great. (A standard neutral black will be a bit flat looking....add some yellow and it will look worse, add some red and the new black may look better maybe worse, add 6-10% of a dark blue and presto the new "blue"-black will look stonger and much more appealing than the neutral black).
Unless he is a color RIP software master, make sure your web/ad guy is not color proofing/testing/approving on his PC. The resolution looks a bit weak as well. Is that a digital photo of your pre? If so try more megapixles if not try slower speed film.
*For you guys in the printing business....I've tried to simplify this a great deal. I am aware of hexachrome, standard six-color process, spot colors and the rest.
