Flexible tube amplifiers ...
0 Members and 1 Guest are viewing this topic. Read 1476 times.
SnapperHawk
« on: 4 Mar 2007, 09:27 pm »
I know Wright Sound has the mono 25 which allows tube rolling for the power tubes (KT66, EL34, and 6L6). I was wondering if there were any other manufacturers that made similar products, meaning a base design allowing the interchange of power tubes without having to twiddle with anything. I have a number of unused power tubes and would like to try them out in my system.
Thanks in advance. :D
Jeff
JoshK
Re: Flexible tube amplifiers ...
« Reply #1 on: 4 Mar 2007, 09:32 pm »
If an amp has bias that is user adjustable, then most all EL34/Kt88/6L6 family amps can be rolled with any of the others in that group.  They have different bias points but otherwise are interchangeable.  So a fixed bias amp would not allow changing of output tubes but adjustable bias amps would.
WEEZ
Imperial
  • Love keeps us in the air, when we ought to fall.
« Reply #3 on: 6 Mar 2007, 01:21 am »
Juicymusic audio has these mono's that I believe will accommodate a lot of different tubes.
It has a real easy bias adjust. Just flip a switch I believe, and twiddle a dial to get a green light. 25w or so. It's called pCat. http://www.juicymusicaudio.com/webpages/poweramps.html
Imperial
JohnR
« Reply #4 on: 7 Mar 2007, 10:48 am »
Hm, I don't think the JuicyMusic amp will take other tubes.
The Quicksilver amps are cool -- the look is reminiscent of vintage amps.
SnapperHawk
« Reply #5 on: 11 Mar 2007, 04:08 pm »
Been away for awhile. Thanks for the information. I really appreciate the help I get on this board.  :D
mjosef
« Reply #6 on: 11 Mar 2007, 10:22 pm »
Response Audio 3205 allows for use of 6550's, EL34s and KT88 type tubes.
I have a 3205 by the way.
Tweaker
« Reply #7 on: 12 Mar 2007, 02:18 am »
Here's another to add to the list (PrimaLuna):
http://www.upscaleaudio.com/product.asp?itemid=500
Bucky
« Reply #8 on: 12 Mar 2007, 03:11 am »
I have at TAD-60 which will accomodate 5 or 6 types of power tube via an easy to adjust bias.  Amp also has adjustable feedback, adjustable triode and ultralinear and more.  Truly a good deal in audio.  You can also find older version on audiogon for pretty cheap.
http://www.angelfire.com/biz/bizzyb/TAD-60.html
There are a couple of reviews here and alot on audiogon.  The guy who builds them is a really good resource also.
dcktr
« Reply #9 on: 12 Mar 2007, 03:12 pm »
Might as well chime in
Great service and Albert will customize to meet the needs of your system
http://www.space-tech-lab.com/Products.html
SnapperHawk
« Reply #10 on: 3 Apr 2007, 11:02 am »
Thanks guys, I really appreciate the help.
Surfing around for other reasons, I found Response Audio. I guess I was checking out the site after reading a review on their mono blocks at 10Audio and came across the stereo amp version. It looks interesting.
I remember the TAD amp now. I found the site one day but couldn't remember the name or address. It's one of the reasons I asked for help. I'll bookmark it this time.
I have a lot of options now. The question is how to make a decision. I guess that's the fun part.
Best regards everyone.
charlez
« Reply #11 on: 4 Apr 2007, 01:07 am »
At the bargain end of the flexible-tube amp spectrum, you may want to check out the 22wpc Ming-Da MC34-B for $375 now on Audiogon that has adjustable bias:
http://cls.audiogon.com/cgi-bin/cls.pl?ampstube&1179273663.
