HDMI Splitter
0 Members and 1 Guest are viewing this topic. Read 1394 times.
klh
HDMI Splitter
« on: 3 Mar 2007, 09:16 pm »
Do any of you know of a 3->1 or 4->1 HDMI splitter that also has a coaxial or optical digital out? I know Sherwood Newcastle makes a 2->1 with that feature, but I really need 3->1 or 4->1. Thanks in advance. My 5 channel integrated amp is a bit antiquated... it doesn't have any HDMI ports. It definitely has to go but finances won't allow for a new one for a while :(.
wshuff
Re: HDMI Splitter
« Reply #1 on: 3 Mar 2007, 09:27 pm »
Why do you need the coax/optical out?  If you can figure a way to get by without that, Monoprice has a 5X1 switcher for under $90.
Or are you really looking for a splitter so you can output HDMI from one source to two displays?  I think Monoprice has one of those too, but it is more expensive.
klh
Re: HDMI Splitter
« Reply #2 on: 6 Mar 2007, 07:26 pm »
My problem is I'm using an old integrated amp in my HT and it doesn't have HDMI in's or out's. I was thinking it would be best to have an HDMI switcher that not only switches the video signal but also outputs a single digital audio wire separately from the HDMI so I can have one digital audio wire going into the integrated. Obviously the best thing would be to upgrade the integrated, but I decided to go for a more expensive PJ and thus don't have the disposable income to get the new receiver... at least not for 6 months.
bubba966
Re: HDMI Splitter
« Reply #3 on: 7 Mar 2007, 05:42 pm »
http://www.pacificcable.com/Picture_Page.asp?DataName=HS-42A
Might just be cheaper to get a new integrated...
kfr01
Re: HDMI Splitter
« Reply #4 on: 8 Mar 2007, 03:15 am »
