AV$
0 Members and 1 Guest are viewing this topic. Read 3822 times.
dblotii
AV$
« on: 3 Mar 2007, 02:45 pm »
Where can I find a review ofthe AV4's?
Dave
Danny Richie
Re: AV$
« Reply #1 on: 3 Mar 2007, 07:55 pm »
I don't believe there are any. It was designed to be more of a full range design for small rooms and we have not moved a lot of them compared to all other models.
RAW
Re: AV$
« Reply #2 on: 3 Mar 2007, 10:54 pm »
I would say the single reson the AV4 has not a large seller,
Is the cabinet is a little complex for the average builders.
Danny Richie
Re: AV$
« Reply #3 on: 4 Mar 2007, 01:34 am »
That and the price of the kit.
I can sell three A/V-3 kits and a pair of A/V-1's for $645 (quantity discount).
That's still $150 less than the A/V-4's. It's those 12 inchers and the 3 way crossover that really add up.
RAW
Re: AV$
« Reply #4 on: 4 Mar 2007, 01:44 am »
Agree
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
Re: AV$
« Reply #5 on: 4 Mar 2007, 03:21 am »
Granted I've never heard an A/V3 or A/V4 ... but I bet the A/V4 sounds a lot like my MTMWW I just completed.  It's essentially an A/V3 for the MTM and 2 M-165x actively crossed at 200hz for the WW.
Dynamics, detail, huge soundstage while maintaining pinpoint imaging ... all those are traits of the MTMWW I made.  I bet a big part of that is the M-130 drivers not having to reproduce bass, and in that respect the A/V4 should be similar.
Correct me if I'm wrong Danny,  but it sure seems like the M-130 excel in this appication.
mas
Re: AV$
« Reply #6 on: 6 Mar 2007, 03:48 pm »
They are competing directly with the OB-5 model, which has generated a lot more buzz.
I have been considering which speaker to build, also. I listen to two channel only in a 15 x 17 room. My impressions are that the A/V-3 is a good place to start, considering my woodworking skills, but the OB-5 is where I want to end up with better transparency, detail and sense of space. The A/V-4 with a Neo tweeter also seems like a good choice, with the added benefit of great bass extension and smaller size.
I wonder how a Neo equipped A/V-4  would sound compared to the OB-5, or standard A/V-4?
Loftprojection
Re: AV$
« Reply #7 on: 6 Mar 2007, 10:49 pm »
I can tell you that the A/V-3 mated with Danny's speaker cables are quite impressive.  I just added a SW-12a sub to my A/V-3 as well.  I am a really happy camper and I have listened to many more expensive kits in audio stores before deciding to build these.  I wonder if Danny ever compared an A/V-3 pair with SW-12a sub versus an A/V-4 pair but I would sure like to ear that.
Danny Richie
Re: AV$
« Reply #8 on: 7 Mar 2007, 12:04 am »
I'd take the A/V-3 and the separate sub.
dblotii
Re: AV$
« Reply #9 on: 7 Mar 2007, 11:52 pm »
So no one out there has heard a pair of AV4's?
Dave
Cacophonix
Re: AV$
« Reply #10 on: 8 Mar 2007, 05:44 am »
Dave
I have ... and like danny mentioned earlier, the cost of the kit was the stumbling block for me.
For less than that price, i could get an OB-5 or pay a wee bit more and get a OB-7.
When i heard the AV-4, the drivers were still not broken in, so it won't be fair on my part to
comment on it.
chainsdb
Re: AV$
« Reply #11 on: 8 Mar 2007, 09:42 am »
really? US$645 for five speakers, which should beat the ascend 340ce in HT setup. nice...if only i knew how to build speakers.
