0 Members and 1 Guest are viewing this topic. Read 11867 times.
Not sure if I'm hi-jacking this thread but there's a few things I read on this and other forums that I'm confused about. Maybe someone here can shed some light.The center opening of a W-baffle or Ripole should be 25 - 30% driver Sd. If drivers xMax (pk to pk) is >10mm the opening should NOT be less than 30% Sd, if xMax is <10, the area should be no smaller than 40%.I'll use the Knight-12 specs from above as an example...xMax of .25" (or 6.35mm)xMech of .50" (or 12.7mm)Sd of 95.033Assuming that xMech is xMax Pk to Pk: .30*95.033=28.5099What exactly do I do with the number 28.5099? 28.5099mm is certainly too small for the opening and 28.5099" is WAY too big.Please forgive my ignorance. I know I'm missing something, can someone help me understand this?Thank you,Max
mcgsxr, Is that your MAW-12 in the OB w/the b200 in your gallery? Looks pretty quality for that low a price.The efficiency seems a little low, what do you drive your MAW-12s with and about how big is your room?Does connecting only one of two VCs have negative effects on a driver?
Who really wants to build a big box?Max
