Can I put a LED in a battery bugle??
0 Members and 1 Guest are viewing this topic. Read 1308 times.
REY
« on: 27 Feb 2007, 06:43 am »
or this will cause some noise? sorry if this has been asked before!
hagtech
Re: Can I put a LED in a battery bugle??
« Reply #1 on: 28 Feb 2007, 07:59 pm »
Sure you can.  I only left it off because of extra current drain.  But in retrospect, it probably would have been a good idea.
Wire up an LED in series with a 10k (or a leftover 13.0k) resistor from V+ to V-.  After the switch.  That gives a very reasonable compromise.
jh
