The V60 OXO
0 Members and 1 Guest are viewing this topic. Read 1571 times.
Housteau
The V60 OXO
« on: 26 Feb 2007, 06:41 pm »
I was looking at the pictures of the V60 OXO and had some questions.
On the OXOs for the other speakers I thought I read that the outputs from them were terminated wires that were ready to connect directly to direct drive speaker terminal inputs.
Are the outputs from the V60 OXO the same, or are they bare terminal lugs needing separate short jumpers for those connections to be made?  If jumpers are needed, what length is suggested?  I see two sets of terminals on the input to the OXO (bass & high level).  Are there three terminals for the output (bass, midrange, treble)?
Will these terminals accept banana plug connections?  I can't quite identify the terminal type from the photos?
Brian Cheney
    • http://www.vmpsaudio.com
Re: The V60 OXO
« Reply #1 on: 26 Feb 2007, 06:59 pm »
There are three output wires from the OXO, bass, mid, and treble.  Each is 2ft long and terminated with ring terminals.  To attach you unscrew and remove the binding post nuts, slip the ring terminals over the posts, and tighten the nuts.  The standard OXO has two inputs which are normally strapped together with jumpers which are supplied.
Housteau
Re: The V60 OXO
« Reply #2 on: 26 Feb 2007, 07:13 pm »
Thank you :).
