Teflon Coupling Caps???
0 Members and 1 Guest are viewing this topic. Read 1412 times.
BRN
« on: 22 Feb 2007, 08:36 pm »
Looking for 0.1uF Teflon coupling cap for my 2A3 SET amp. I have read about the V-cap and Sonic cap, and these seem to be the ones everyone talks about, but there is no direct comparison between the two. What are some of the comments about the sonic differences between the two, because I do not believe that one is truly better then the other. They just have different sonic signatures.
Brad
Bill Baker
    • Musica Bella Audio
Re: Teflon Coupling Caps???
« Reply #1 on: 22 Feb 2007, 09:07 pm »
Yes Brad, you are correct, "They just have different sonic signatures". I have been using both for some time now and here is my take on their differences in a nutshell.
 The SoniCap Platinum is more pure and precise while the V-Cap has more of a sense of texture and body, especially in the midrange. Both are extremely resolving with excellent transparency and inner detail retrieval.
JoshK
« Reply #2 on: 22 Feb 2007, 09:54 pm »
I think it would be interesting to compare these (SC/V-Cap) to the Russian teflon caps.  I got a ton of the Russian variety because they are cheap.
Kevin Haskins
« Reply #3 on: 22 Feb 2007, 09:59 pm »
There might be some USA made Teflon caps available this year at reasonable prices.   Just a rumor I heard.  ;-)
JoshK
« Reply #4 on: 22 Feb 2007, 10:11 pm »
Solen (SCR) makes some teflon caps too that are cheaper than other boutique teflon caps. You can get them from solen.ca.
