0 Members and 1 Guest are viewing this topic. Read 10867 times.
I'm having an electrician come over in a couple weeks to run two dedicated 20 amp lines from the box to my audio room. Electrician reported he can run: 1) two separate lines, one each to a separate duplex (separate hot/neutral/ground for each line); or 2) a different wiring set-up (I'm depending on my memory here!) in which I believe he stated the hots are separate, but the neutral and ground are shared - sorry I cannot remember the name of the wiring for this set-up option.My inclination is to spend the bit of extra $ for scenario #1. I believe I've read somewhere that it's preferable to keep the analog and digital on separate AC lines; thus, #1 seems to do this.To complicate things even more, I'm wondering if it would be ok to have the electrician do scenario #2 for my analog gear (thus, four outlets/two duplexes - would have two Odyssey Extreme Mono amps, Odyssey preamp, and my turntable on these lines). I then could have a separate line as in #1 for my digital gear (two outlets/one duplex - I currently only have a cdp, but would leave to expand in the future re: DAC). This would provide for a total of six outlets, four analog and two digital.Opinions are desired regarding the above. In advance, thanks for your constructive comments.
My electrician ran 2 lines (under the crawl space) to my audio closet. Total bill was $265, with 90 of that in the Romex. What was your quote? The only choice I got was whether to have a 4 plug receptacle per line or 2 plug receptacle. I chose the 2 plug, but had no real "intelligent" reason for choosing it. I have 2 Mono Extremes on one outlet and the other outlet I have a budget type power conditioner (VanEvers) which feeds the other stuff ( candela pre, Arcam HT receiver, cdp, sub amp) In the only other outlet that's not being used I've got the AVA DAC plugged directly into the wall. I'm curious to hear more about option #2 for you along with any other suggestions as I'm open to making some changes to my setup.Rob S.
You didn't mention the gauge of wire he'd use. Residential code allows for 12 gauge with 20 amp circuit breakers (the largest used in houses) and that's what I'd do. (Why do audiophiles buy 10 gauge power cords when their house wiring is typically 15 amp breakers and 14 gauge wiring?)
The problem with having different components of your system plugged in through two separate dedicated lines is the two long runs of safety grounds all the way back to the service panel. That means more resistance and any chassis leakage currents will result in greater voltage drops and more noise between the components plugged into the two lines.Ideally everything would be plugged into the same line with the safety grounds tied together through the lowest possible resistance.Here's a good piece on that issue by Bill Whitlock of Jensen Transformers:Hum & Buzz in Unbalanced Interconnect Systemsse
Good point Steve. I recall reading an article ages ago saying that dividing components across multiple dedicated lines was more likely to increase hum due to different potential. This would seem to suggest installing a higher rated single line (perhaps 30A, 10 gauge) for all components and then implementing isolation/conditioning between wall outlet and components to treat any grunge put back on the line by noisy equipment.
Not being an EE, I wasn't sure whether multiple dedicated lines consisting of the same wire type, gauge, length and age could have different resistance/potential and therefore cause issues? From your comment it seems that it is more a function of the equipment on each line that causes the problems, rather than the lines themselves ...is that right?
So ... in the situation where we run all components off the same dedicated line, and use the same type and length of power cord on all components, but plug the power amp and subwoofer directly into the wall and the source and pre-amp into an isolator/conditioner.... will the 'direct' connected components see a different potential to the 'conditioned' components, thus causing hum?
Best to check your local electrical codes before spending the money on a separate dedicated ground for your audio gear it is decided illegal to do this where I live. One earth ground per house. period.
That doesn't mean it isn't right as far as how well it will perform, but most electricians won't do it.
Can you elaborate on that a little more? It doesn't have any relevance on audio components?And please refrain from any expletives.
Steve, I'm interpreting that what you're recommending I should do is, and I quote my original post: "or 2) a different wiring set-up (I'm depending on my memory here!) in which I believe he stated the hots are separate, but the neutral and ground are shared..." Thus, two duplexes running off the 3/2 wire. Is this in fact what you are stating? In advance, thanks to you and all those who have responded. This is getting interesting.
I clarify that I am not going to have a separate earth ground for the audio gear. All house wiring, including what the electrician will be doing, comes from my home's single service panel.
I also add that I'm living in the country - biggest issue with power here is the storms that occasionally interrupt service.
Furthermore, I note I still haven't read anything specifically addressing keeping the digital separate from the analog...
Sure, I can do that. I'm multi-talented. Instead I'll throw in an epithet or two, how's that?
Is that what I've heard for years referred to as star grounding ?
What exactly causes groundloops? (I forget that one)
Can you sing and dance too? Ok, I'm envious, I can't do either. Pretty lousy at juggling too....
Well generally speaking the greater the resistance between the safety grounds of the components, the greater the potential for hum and buzz. So in the example you give here, it would stand to reason that the path ghrough the isolator/conditioner over to the safety grounds of the other components plugged directly into the wall would be increased.
Actually, a literal earth ground has no relevance at all to an audio system. And it's only used on the AC mains system for lightning protection.
