Frybaby hookup questions
0 Members and 1 Guest are viewing this topic. Read 1193 times.
spot1019
« on: 20 Feb 2007, 03:12 pm »
Jim,
I recently purchased a Frybaby from AA. I have a couple questions.
Why does it say in the manual that only one digital cable can be burned at a time ?  Couldn't the same method be used as burning a set of interconnects, where each digital cable come out of FBabys rca jacks for voltage burn, and cables are shorted with Female-Female connector for current burn ?
Could you burn mutliples sets of cable at once using several Female-Female connectors ?
One more and I'll stop buggin ya. I have some jumpers I made for NAD integrated amp for pre-out amp-in. It is only a single lead with the center pin from an RCA plug. Would that be able to be burned on the FBaby by plugging into the center pin of the RCA jack ?
thanks
John
hagtech
    • http://www.hagtech.com
Re: Frybaby hookup questions
« Reply #1 on: 20 Feb 2007, 06:53 pm »
Yes, you can burn in any number of cables if connected in series.  Just daisy chain them.
The nad jumpers connect to center pins of RCA jacks.
jh
