Brad Jacobs
David Ellis
    • http://www.ellisaudio.com
Brad Jacobs
« on: 20 Feb 2007, 01:54 pm »
Brad,
I have attempted to return a few emails from you on a few different topics, but they are getting kicked back.  I really don't know why??
This is the most recent rejection:
Sorry, we couldn't deliver your message to the following people or distribution lists. We hope the information below helps you understand what happened. Please read it carefully.
[email protected]
There's a problem with the recipient's mailbox. Microsoft Exchange will not attempt to redeliver this e-mail message for you. Please try resending this e-mail message, or ask your system administrator for help.
Sent by Microsoft Exchange Server 2007
Diagnostic information for administrators:
Generating server: axcelis.com
[email protected]
#550 5.2.0 STOREDRV.Deliver.Exception:MapiExceptionNamedPropsQuotaExceeded; 6363,6363,6363,31229,6363,17597,22787,22787,22957,19693,16635,17917,27341,22957,19693,16635,17917,27341,22787,22957,19693,16635,17917,27341,5415,7867,4475,4603,5323,10786 ##
Original headers:
Received: from ma805ex.axcelis.com (172.23.245.51) by ma802ex.axcelis.com
 (172.23.245.53) with Microsoft SMTP Server id 8.0.605.16; Tue, 20 Feb 2007
 08:52:36 -0500
Received: from smtp120.iad.emailsrvr.com ([207.97.245.120]) by
 ma805ex.axcelis.com with Microsoft SMTPSVC(6.0.3790.1830);    Tue, 20 Feb 2007
 08:52:35 -0500
Received: from ellisaudio.com (webmail19.webmail.iad.mlsrvr.com
 [192.168.1.17])   by relay2.r2.iad.emailsrvr.com (SMTP Server) with ESMTP id
 3AEAF44E078   for <[email protected]>; Tue, 20 Feb 2007 08:52:31 -0500
 (EST)
Received: from  ([192.168.1.71]) (proxying for 68.227.169.247)        (Webmail
 authenticated user , [email protected]);        by www2.webmail.us with
 HTTP;        Tue, 20 Feb 2007 08:52:31 -0500 (EST)
Message-ID: <[email protected]>
Date: Tue, 20 Feb 2007 08:52:31 -0500
Subject: RE: Note from Brad, Montana
To: <[email protected]>
Reply-To: <[email protected]>
X-Mailer: webmail 6.0
MIME-Version: 1.0
Content-Type: text/plain; charset="UTF-8"
X-Priority: 3 (Normal)
Importance: Normal
X-Resend-Type: reply
X-MB: INBOX
X-UID: 4903
X-Autosave: 1171979550.438
Content-Transfer-Encoding: quoted-printable
Return-Path: [email protected]
X-OriginalArrivalTime: 20 Feb 2007 13:52:35.0756 (UTC) FILETIME=[604AEEC0:01C754F6]
X-TM-AS-Product-Ver: SMEX-7.0.0.1499-3.6.1039-15008.003
X-TM-AS-Result: No--1.745400-4.000000-2
Brad,
I did respond - twice. Your email's are getting kicked back.
Testing... testing...??
Dave
Dave Ellis
www.ellisaudio.com
-----Original Message-----
Sent: Mon, February 19, 2007 8:51 pm
To: [email protected]
Subject: Note from Brad, Montana
Hello Dave,
Did you get my e-mail on the CSS WR125, what do you think of this driver? Al uses it in his HT speakers.
I forgot to mention if you are interested in an accelerometer to measure speaker cabinet vibration, let me know. I built a remote unit that measured motorcycle oscillations, it was batter powered and saved data to a tape. Your application would be much easier. You should be able to set the output up to interface with your speaker measuring system. Instead of a microphone use the accelerometer. I also spent three years working with acc's and gyro's on guidance systems.
I would not charge for this, after reading more of your AC entries you could use some repayment. Honestly Dave, I agree with your wife. You need to make some coin. After speaking with you I have concluded you probably know more than most boutique speaker designers. On top of this you are honest about the science/engineering or lack of within the audio industry. There is way too much hype and pseudo science within the industry.
I wish TC sounds would get with the program, you are losing ROI on the work you have done. I would have purchased a three way from you.
Take care,
It appears that you read the AudioCircle grunge.  Please acknowledge that we have good communication.  Then we can use this string for discussion.
Dave
David Ellis
Re: Brad Jacobs
« Reply #1 on: 22 Feb 2007, 09:55 am »
This note is for Brad.
I really don't know anything about the WR125 driver you mention.  Nonetheless, I am in the mood to ramble a bit.
1.  The WR125 frame appears well suited to a larger spider.  I believe this is important and is a normally a good thing.  It is always a good thing to have a larger spider when a longer throw is needed.  The larger diameter spider will provide greater linearity through the length of the voice coil travel.  The only downside to a larger spider is that it will also have a higher moving mass.  This will reduce the sensitivity and Fs of the driver.
2.  Discerning the sound character of the driver isn't possible for me without actually hearing it.  There is an art to properly integrating the cone and surround.  This is true for stiff cones and soft/flexible cones.  If done correctly the surround will damp unwanted cone vibration, yet move with the cone when desired.  Some of this can be measured with a frequency response.  Some can be measured with a waterfall plot.  Some of this can only be measured with a Kippel.  Oh, and it can also be heard with the human ear.  Not all paper cones sound equal.  I really liked the early GR130 Paper Cone driver from GR Research made by Peerless.
3.  X-Max is measured differently depending on manufacturer.
Some manufacturers measure the distance from the "top" of the voice coil to the top of the top-plate.  This may also be called the air gap.  For example, an 18mm overhung voice coil having a 4 mm thick top plate would convey a 6mm X-Max.  IMO, this seems fair and reasonable.  While the motor force is somewhat reduced at full X-Max (depending on motor configuration), there is still a good motor grip on the voice coil.
Other manufacturers measure the distance from the "top" of the voice coil to the bottom of the top-plate.  For example, an 18mm overhung voice coil having a 4 mm thick top plate would convey a 10mm X-MAX.  A thicker top plate will increase advertising impact, but decrease performance.  IMO, this is unreasonable because at full X-Max there is no substantive grip on the voice coil.  Nonetheless, I have seen this method used for advertising.
I have thought of using an accelerometer to analyze cabinets.  The raw part is fairly inexpensive, but it remains in the category of things that "I really should get accomplished".  It would indeed be very simple to attach to loudspeaker measuring gear.  The accelerometer would simply replace the microphone.
I do appreciate your sentiment  :) , but my our perspective on this issue has changed slightly.  I am smart enough to know this hobby is a blessing.  How many guys have a hobby that only costs $1k/yr (or less) to maintain?  As such it's a blessing.  And, my wife has mellowed too.  She recalls that her Father had a small hobby farm that never did make any real money.  The farm lost money many years.  Crudely crunching the financial numbers on his corn planted in sandy fields resulted in @$ .50/hr IF none of the 40 year old equipment broke.   My wife and I both believe that all things will happen in God's time.
Me too, and I appreciate your vote of confidence.  Certainly a good 3 way will sound better.
Herein I would like to ramble a bit.
In my formative years any decent speaker was a 3-way.  This perspective was very deeply ingrained and seemed immutable.
Nowdays a good 2-way can sound... really darn good.  Certainly many companies have sold a plethora of very respectable 2-way speakers.  At the top of the heap, kharma sells a 2-way floorstanding speaker for $45k: http://www.audiofederation.com/dealership/kharma/ .  Sonus Faber sells a good 2-way.  The ACI Jaguar is also exemplary.There are others to, but the hour is late and my mind is getting foggy.  Anyhow, my point is that a 2-way can sound very good.  I would much rather listen to a good 2-way (i.e. the 1801 or Jim Salks 2-way) than the vast majority (perhaps all) of the $3k (or less) 3-way speakers.   IMO, 3 lesser quality drivers cannot equal the results obtained when using 2 very high quality drivers.
My desire to build a big 3-way speaker isn't driven by a holistic desire for better sound.  My desire is driven by male testosterone, and American lust for something bigger & better.  I have a similar lust for a fancy sports car or some Marchesini forged magnesium wheels for my Aprilia.  The only way I can truly justify the construction of a larger speaker is through my mental exploration during the process and the resultant knowledge obtained.  I really don't think it can be justified from a value perspective because it'll be very very expensive.  Sure, it'll sound better than the 1801, but there are so many other things in hifi that can be obtained that are a better value when implemented in a stereo system.
Lately I have started to believe quality control is the most neglected aspect of loudspeaker manufacture, and the aspect most customers assume competence.  This is a sad dichotomy.  Fortunately there is at least 1 guy in a good postion to convey the truth about this arena.  Dennis Murphy is a professional postion of legal immunity with regard to such issues, and has conveyed very painful truth regarding many of the more commercial speakers he has tested.  Probably the most painful was the Norh 9.0 from Mr. Barnes.  http://murphyblaster.com/content.php?f=marble.html  I do NOT think this an is the only speaker with such problems.  I actually think Mr. Barnes is well above average.  I have heard many other stories of commercial measurements of "big company" X loudspeakers that were equally bad.  However, as a loudspeaker manufacturer without substantial legal staffing I cannot an will not convey this openly.  //  Heck, a couple years ago I noticed that Monster Cable was suing a company that made kids video tapes having the word "Monster" in the title.  I didn't follow this story completely, but it may have killed the kids video tape company.
okay... that's enough rambling.
Good night,
Dave
