0 Members and 1 Guest are viewing this topic. Read 9735 times.
I could easily be persuaded to accept the idea, especially after having experienced how really wrong the stereo format is compared to csero's implementation of amphionics.
Josh can you really build/copy a Tn-P if you had enough info to get started?
The issue I see with the TP is one of acceptance.
JohnBased on Sunday's little experiment, I hope you take a few minutes to try even the 626R L/R w/ the V60 center.
Let's go back to the drawing of the VLA in John's first post, on the first page, and Brian's post down a couple from that says there is a passive in the bottom and on the side, as shown in the diagram.Question #1: Does the chamber inside the speaker allow all 4 woofers to be connected to both passive radiators? Q#2: Would it be better to have the side passive near the top of the cabinet? What's the stagegy here?I'm wondering about timing issues in getting a back wave from the top woofer down the speaker, and pushing out through either the side and/or bottom.And while I'm musing, Q#3, wouldn't it be better to have 4 passive radiators each on the side adjacent to a woofer, and perhaps have each woofer in its own chamber?Just wondering, and trying to understand.
