TL for bass drivers in OB-5?
0 Members and 1 Guest are viewing this topic. Read 3407 times.
nodiak
« on: 19 Feb 2007, 05:39 pm »
Danny would this work ok? I've heard some say TL's have a drop in efficiency vs. the same drivers in BR. Curious about this as I have been looking at A/V-3 and OV-5's. Seems a TL of the same height as the BR cab could be worked out from A/V-3 design. So the OB-5 could maintain it's dimensions, but maybe a deeper bass cab.
Don
« Last Edit: 19 Feb 2007, 07:23 pm by nodiak »
Danny Richie
Re: TL for bass drivers in OB-5?
« Reply #1 on: 19 Feb 2007, 07:38 pm »
You are correct. A TL line box like that used in the A/V-3 could pretty easily be implemented into the OB-5 design.
However, If you are using a sub to handle the bottom octave it might be just as well off as is.
Daygloworange
  • www.customconcepts.ca
« Reply #2 on: 19 Feb 2007, 08:02 pm »
Just off hand Danny, what would the volume of the OB 5 or OB 7 need to be to do a TL for the woofer section? What size difference would there be?
What do you feel the difference in bass quality and room loading would be? I like the way the AV/3's  bass performs in room quite a lot. Probably more so than ported speakers.
As you know, I do have a sub.
Cheers
Danny Richie
« Reply #3 on: 19 Feb 2007, 10:18 pm »
The same as the A/V-3 box is fine. You just have to maintain the same port sizing as the A/V-3.
The TL line times the output to take advantage of pressure changes in the box to give more output at the tuning frequency than you get with a port. In this case a little higher output in a little lower range.
Daygloworange
« Reply #4 on: 19 Feb 2007, 10:28 pm »
Ok, so for the OB 5, it's a more straight forward switch from a ported design. Because I'll be building a hybrid OB 7, with all 4 woofers at the bottom, could a TL design work for the woofer section? Or does it have to be sealed like the original design?
Again, keep in mind I run a subwoofer.
Cheers
Danny Richie
« Reply #5 on: 19 Feb 2007, 10:41 pm »
With four of them, they'll need to be sealed.
Daygloworange
« Reply #6 on: 19 Feb 2007, 11:26 pm »
Ok. Thanks.
Cheers
nodiak
« Reply #7 on: 20 Feb 2007, 05:17 pm »
Danny, as a few discussed in the recent tl thread in the Lab forum they are finding tl's easier to place in a room, avoiding boom of br's. I haven't had a tl for some years and remember them being very smooth in the bass in general, maybe they did avoid some in room bass humps, but I didn't think about that then.
The more I looked and read about the A/V-3 the more I wanted to try a tl again. If i go for OB-5 I think I'd want to try tl loading too. I do use a sealed sub now but am also thinking about trying an mltl sub I have plans for. I might be missing tl type bass without realizing it.
I'm a  couple weeks away from ordering, appreciate the discussion.
Don
Voncarlos
  • OB5s in Stripes
« Reply #8 on: 1 Mar 2007, 07:26 pm »
What does "TL" and "BL" stand for ???
Carlos
Danny Richie
« Reply #9 on: 2 Mar 2007, 02:57 am »
BR stands for bass reflex. TL stands for transmission line.
tubesurf
« Reply #10 on: 10 Mar 2007, 08:02 pm »
Hi Danny,
I am sure you are busy with all your projects but I wonder if you could put together a TL version OB-5 cabinet drawing on the website.   My OB-5 kit has been ordered and I am interested in a TL version.    I see the AV-3 volume is the same as the OB-5 - would you just maintain the area and length of the TL line in the AV-3 proportioned to the OB-5 dimensions?
klh
« Reply #11 on: 16 Mar 2007, 12:40 am »
I recall reading a few years back that woofer control in TLs is not as tight? If that's true, would you say 4 sealed M130x's would outperform 2 M130's in a TL (either in a modified OB-5)? What are the trade offs?
Danny Richie
« Reply #12 on: 16 Mar 2007, 01:44 am »
Woofer control in a TL line is very good.
4 M-130X woofers would be very tight and controlled for sure. Bass would be really clean and distortion would be really low, but they would not play as low.
klh
« Reply #13 on: 17 Mar 2007, 07:37 pm »
which begs the question... how low will they go?
Danny Richie
« Reply #14 on: 19 Mar 2007, 09:28 pm »
The parameters of the M-130X are pretty close to the standard M-130. -3db down points will be in the 55Hz range. Loading them in a TL can extend that some. -3db down points in the low 50's to upper 40's is possible.
