Any difference between a 14bst and a 14bsst?
0 Members and 1 Guest are viewing this topic. Read 1570 times.
jakeman
« on: 19 Feb 2007, 05:09 pm »
I've been getting different opinions on this question so I thought I would post it.  One side tells me its the same topology and innards except for the front plate.  If that's the case can I obtain a new front plate from Bryston for a 14bst?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Any difference between a 14bst and a 14bsst?
« Reply #1 on: 19 Feb 2007, 05:29 pm »
Hi,
The 14B ST was the first of the 14B SST Versions. The only difference is the 14B SST C-Series has a slightly different power supply.
You can not put a new SST C-Series Faceplate on the older ST.
james
