Bryston and B&W
0 Members and 1 Guest are viewing this topic. Read 2321 times.
amdan
Bryston and B&W
« on: 19 Feb 2007, 09:00 am »
Some of you may recall my recent post querying if Bryston gear and B&W match well. I was particularly concerned with the brightness that I was getting. I am happy to say that I have resolved the issue. I can report that the problem had nothing to do with either the Bryston or the B&W speakers. The system now sounds very nice to my ears.
So I can say that the post I saw in another forum saying that Bryston and B&W don't go together is incorrect.
mitcho
Re: Bryston and B&W
« Reply #1 on: 22 Feb 2007, 04:15 am »
how did you resolve the issue?
amdan
Re: Bryston and B&W
« Reply #2 on: 22 Feb 2007, 10:00 pm »
Changing the power cable on the CD player. The harshness was coming from upstream and being faithfully reproduced by the Bryston and B&W.
mitcho
Re: Bryston and B&W
« Reply #3 on: 22 Feb 2007, 10:06 pm »
that would do it.   I have been using Virtual Dynamics power cables and they tend to be very smooth in the top end.  No harshness at all.
glad you resolved it.
thanks
ryder
Re: Bryston and B&W
« Reply #4 on: 25 Feb 2007, 02:50 pm »
It's amazing that some folks in Audiogon described both Bryston and B&W as unrefined and bright especially with B&W's metal dome tweeters. Good to hear that you've rectified the situation. I was a huge fan of B&W's having owned the N805 before switching to some PMC's.
mitcho
Re: Bryston and B&W
« Reply #5 on: 25 Feb 2007, 03:03 pm »
both of the brands i.e. Bryston and B and W are revealing and usually the brightness is a short-coming of other equipment/ cables in the chain rather than the amp or the speaker.
they are neutral and give you exactly what is fed to them.   If you have something weak in the chain, they will tell you.   They don't gloss it over like some other products.
