FM acoustic 155 vs Nagra PLL
0 Members and 1 Guest are viewing this topic. Read 1558 times.
aod
« on: 18 Feb 2007, 06:16 pm »
I've heard the 155 and it is great, super speed and slam... what is the Nagra PLL like?
Imperial
  • Love keeps us in the air, when we ought to fall.
Re: FM acoustic 155 vs Nagra PLL
« Reply #1 on: 19 Feb 2007, 05:28 pm »
That depends on how you connect it.
It is best connected via the RCA connectors.
It is two very different pre-amps you have there.
The PLL will/should be better at microdynamics and timbre of strings and stuff.
The 155 is a transistordesign, and the PLL is a tube-pre... (you can tuberoll.)
But if you can afford the 155, get it. The PLL is a more smallscale music pre.
It's a studio playback monitoring pre.
They are both so neutral, you can't really tell them apart like that.
But I would guess that the PLL will be a more cool sounding pre, most likely a bit lacking in vocal range bloom on male voices (on the "oh" sound, chest growl you know...  :D ) ... just a pinch!
I'm a tubelover, but on the account of FM, I'd go for the 155 anyday!
Imperial
« Last Edit: 19 Feb 2007, 05:41 pm by Imperial »
